QVL has up to 105w listed…
The 3700x is rated for 65w… so no problem
Id only want up to a 3700, since I dont over clock and could save $20-40 (guessing)
it says it can, but I dont think I would. At least not with extended heavy loads.
challenge accepted
I bet the heatsink below the socket has more VRM stuff. It looks like the entire top half of the motherboard was rotated 90 degrees counter clockwise. Even the 24-pin looks like it’s at the top of the board instead of the right side.
You’re right, Thats gotta be the RAM VRM and maybe SOC.
I bet its 3 phase under that other heatsink.
Ok so maybe its 4 + 1 possibly? or 3+2
ram vrm is off to the side not visible in your pictures. Either way that should be enough power stage to not cook the thing with a 3950x in it. It certainly wont boost to the moon, but it will hold.
ASRock is fond of the 3+2 layout, so I’d guess that is what they are using again.
Either way, a three or higher phase design should be fine for even 105W CPUs without an OC in my opinion.
Yeah 3 is fine
Lot of blue lights for a Team Red build
Otherwise, 10/10
I couldnt immediately tell that was a choke from the side profile.
you want to know how old that blue LED fan is…
it came in an Antec 300 case (that I bought back in 2010)
Some Parts Never Die™
“What is dead may never die!”
The next weekend that grandparents keep my little one… Will likely be my proxmox upgrade date.
Would you be so kind and notifiy ASRock Rack’s BIOS development team about that?
It’s a 3+2 likely yup, i think that i see two driver chips.
One at the Soc rail and one for the Vcore rail.
Controller likely an Intersil.
