My computer build is nearly finished, it is missing the GPU and optical drive, it was working fine the fans were spinning and such all LED lights were on, no problems. I open it all up to do some cable management as it was a jungle in there, replug things, re-arrange things etc and now my pc wont turn on, every now and again when I click the power button a LED light on the mobo comes on for like half a second then goes off, no fans nothing.
I've unplugged everything again and I'm going to redo it on wednesday when my parts arrive, basicly what I'm asking is what should I specficly make sure are plugged in properly, what things should I double check and such.
I have left the power connector in as it was a bitch to plug in and out, but I assure you it is as far in as it can go (I learned from previous problems).
