Nice project for torrent fans.
it autonomous searched for torrents on the web en collect them in a database so you can search for them.
Details can be found on the github page. On how to install it. (al on the bottom of the page)
(disclaimer its alpha now and it will attract every torrent that it can find including porn and illegal stuff but it will only index them that they exist.)
Hm, looks very interesting. Not sure about the legal part though. It is just an indexer of sorts, right? So since you’re not downloading any content (without actually getting the torrent I assume) you should be safe? Idk how agencies work, I know they get into torrent swarms on a tracker, but on DHT? Not sure… Then again just by using a torrent client with DHT enabled you’re technically getting the same information, it’s just not accesible right?
It only index them yes. It doesn’t download it, but the maker himself warned about people getting offended if there is porn in there search results or illegal stuff. so it just pass that trough here as a warning.
Well, it’d be interesting if there will be filters for the torrents, but since meta-data in a torrent is very limited I don’t assume you could easily filter for “all anime” or whatever.
Filetype, size, name etc shouldn’t be a problem I guess.
Does it act like a node that also redistributes its database though? That would be very interesting once they get the ability to delete from the database, could get the illegal stuff of there (it would still be in the swarm but at least people wouldn’t be getting it from you).
depends if its in the meta data.
But its alpha right now. I think if you mention the stuff to the maker he will respond and think about the implantations.
Right now its a vacuum that just sucks all torrents.
Yeah i was thinking of that too. It should be possible to implant that yourself. The tracker and the client to look trough the database are separate of each other. Its possible to build your own client to interact with the database and modify it and flag stuff that shouldn’t pop up.
I think that once there is a filter system that filters out the illegal stuff, this will be great! Not going to use it if there is even a chance of illegal files being saved onto my drive.
There will never be a real filter, but its like @mihawk90 pointed out not illegal to have the metadate stored. It’s still you’re call to actually start downloading the content that it refers too.
Yea that is a small risk. I think people should understand the risks even tho i would take that risk personally. Just because its ridiculous (that we have to be afraid for this).
Mh, not sure if they can even track for that, then again this tool would be perfect for law enforcement as well
The thing is, you have this kind of metadata anyway if you’re just using a normal BT Client. Even when just downloading your usual Linux Distro and have DHT enabled, you still receive this data. Now of course you can’t look at it or use it, but it’s still there
