Hi everyone,
I’ve been experiencing a long-standing issue with this machine where any time I try to install software through apt, it tells me "E: dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’ to correct the problem. "
But whenever I run that dpkg command, it then runs through its paces until it gets to the GRUB OS Prober, at which point the computer freezes for about 30 seconds, then reboots itself.
I also can’t do update-grub, since that also makes the computer crash itself in the same way.
I’ve experienced this in the past, at which point I reinstalled the OS, but now the exact same issue has come back, leading me to think there is a deeper problem here.
I have only ever run Ubuntu 18.04.3, but would be willing to install another OS, if people think it would help.
Happy to provide any kind of logs or whatever people want. Just let me know. Response time might be a bit slow since I have a full-time job
Thanks!
