I have a macbrook pro m1, linux professional by trade in the HPC space. My work machine is also an M1 pro.
At home I have 2x CRG9 displays running full resolution 120hr (no HDR or variable refresh rate).
I am looking at the KVMs to make it easy to swap back and forth in a WFH setup.
Would the regular 2 system twin monitor 1.4 setup work? I currently use 2 DP cables and 2 ports on the mac. They are close by so I can use the very short cables from the machines to the KVM.
Also is it ok to use the USB power version? Or should I stick to the standard version? This would mostly reduce cable clutter. I have used smaller Dell monitors at work that provide Power + Video and it’s nice and clean but they are not the same resolution and no KVM in play.
Thanks,
