Mac OS VM - Looking for high performance remote solution for headless usage [Solved]
Hi, I am looking for a high performance Remote solution for Mac OS or a working version of Sunshine.
Situation:
I have a Mac OS VM running in Proxmox with a GPU passthrough (AMD RX 6600). I am using it mostly for XCode and FinalCut. I used the local Intel USB controller on my previous system. I have a AM4 system as host so passing through the USB controller isn’t a option anymore. (USB support is really wild and flaky on Hackintoshs with current versions of Mac OS with required USB port mapping even if the chipset is supported, so I was stuck at USB 2.0 speeds back then, because I really didn’t want to go through mapping every single port.)
Goal:
Running Mac OS headless with high performance video connection, preferably moving the entire VM + GPU to my fileserver. Having audio output on the client.
Problems with Sunshine on Mac OS:
Sunshine (or the Moonlight client) only displays the first frame and doesn’t update it. Sometime it cycles through 2 frames in reverse order.
What remote software are you currently using? Preferably the client should run on Linux and Windows
I found a solution. With the brew version you can also install the nightly / beta. This includes the latest fixes .
brew install sunshine-beta
You have to remove the current versions, it appears settings are kept between versions.
Now I can move the Mac OS VM to my server and have a high performance remote solution for Mac OS for my local network with audio too.
