Hello All.
I am building a computer for a collegue who is a Mac user. What gpu do i need to give a really good mac os experience on Linux in vm. the buget is limited, so nothing priced to high.
Thank you in advance.
Paulq
Hello All.
Paulq
If you can find it for cheap, a Saphire AMD RX 580 is fine and will run without any additional driver or kernel modules in a Mac OS VM. Please be aware a lot of used ones floating around have been used for Crypto mining and might not be in good shape.
I use a newer AMD RX 6600 with the appropriate kexts and boot arguments. The kexts should be supplied with the open core bootloader.
