Not sure if this is the right formum, apologies if it should be somewhere else.
I have Mac Book air provided by my job. I normally play on my PC because I am not a Mac fan at all.
I'm heading home for Christmas which means leaving my ancient PC at home and in order get some sort of gaming fix I will have to play on the Mac.
When launching a Mac compatible game from Steam, it opens and closes straight away.
When launching directly from the executable I get a crash report. I've searched the web to try and make sense of the report. Best I got so far was courrupt memory or corrupt hard drive (adobe formum for photoshop with the same error message). Ran the memory tests and hard drive scan & repair but no affect.
I don't really have an option to format the Mac as its not actually mine.
I have uninstalled Steam, downloaded it again, uninstalled the games and reinstalled.
It will not ruin my Christmas but certainly would make it better if anyone knew how to fix this.
Here's the error message I get when running some games from Steam, exmple below is from The Witcher - Enhanced edition
Mac OS X 10.7.5
1.7 GHz Intel Core i5
4GB 1333 MHz DDR3
Process: WineskinLauncher [1067]
Path: /Users/USER/Library/Application Support/Steam/*/The Witcher.app/Contents/MacOS/WineskinLauncher
Identifier: 105019737421085468.wineskin.prefs
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [139]
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000008fe00010
VM Regions Near 0x1a84d53b:
MALLOC_SMALL 0000000000800000-0000000001000000 [ 8192K] rw-/rwx SM=PRV
__TEXT 000000008fe04000-000000008fe37000 [ 204K] r-x/rwx SM=COW /usr/lib/dyld
Any help or advice is greatly appreciated (other then throw the Mac away)
Dave
