Specifically, when the MB only has a M.2 slot on the back.
Is heat an issue here, there’s usually no airflow back there…?
Like so:
Like so:
Generally it shouldn’t, most M.2 SSDs are already designed with operating temperatures in mind.
The only negative would be throttled throughput due to the controller getting to hot, the Flash actually likes being warm.
