Hello there,
I am currently building a 2400g ryzen system for my friend.
I told him to get a m.2 ssd so he got this western digital one.
I tested it on my laptop and it works fine.
However on the pc im building it isnt detected by bios or windows.
Im using the Gigabyte b450m ds3h .
Im pretty sure that it supports m.2 sata but it does support nvme primarily.
I tried updating to the latest bios but bios and windows still wont detect this ssd.
I do not have an NVMe drive lying around sorry so I can’t test that.
The product page suggests that NVME and SATA are both supported.
The slot is labelled as M2A and it has the 1 slot with 2 notches for both types of ssds.
I think you may have misread that screen shot. Only SATA will work with those processors listed, not SATA will only work with those processors. With Ryzen SATA or PCIe/NVMe will work.
The reason why it calls out those processors is because they don’t have as many PCIe lanes as a Ryzen CPU, so when using any of those processors it will default to SATA only because of the zero PCIe lanes available to the M.2 socket. Ryzen will support NVMe or SATA.
If any other computers are available with an M.2 slot I’d suggest @Lightswrath101 try the SSD in the other computer. Likewise, if there are any other M.2 SSDs around I’d suggest trying one in the computer having troubles. If the WD Blue works in another motherboard or if a different SSD does not work in the Gigabyte board, then the Gigabyte board is likely the culprit. But if the WD Blue does not work in another motherboard or if a different SSD works in the Gigabyte board then the WD Blue is likely the culprit.
