I have X570 Aorus Pro and 970 Samsung Evo. I tried install that to the second slot as first one is occupied. But apparently the GPU that is sitting above it is making it very hot.
As I would like more fast storage, I am thinking about M.2 PCIE adapter.
The slot just below the GPU is X8, the tiny slot below that one says PCIEX1_2 and the one under it is X4, which would have most distance to the GPU.
This one for example has a fan in it which I would like.
Would I leave performance on table if I install that one to X4 which has most clearance to the hot GPU?
