I’m curious if anyone in the community has experience using lvm raid1 alongside its dm-integrity support (link).
For context, I have a logical volume in raid1, with integrity enabled in bitmap mode. I’ve found it rather cumbersome to use the standard lvm tooling in multiple cases which on the surface seem like they should be able to work.
My setup is composed of HDDs for the data storage, and I have 2 sata SSDs in the volume group as well which are being used for the integrity data.
Getting all the integrity data to live on the ssd’s wasn’t straightforward. I felt like I was essentially “tricking” lvm into putting it there rather than being able to specify dedicated integrity/checksum PVs. But I did manage to extend the LV in clever ways to get the integrity on the SSD PVs eventually.
In general things seem to work fine. The bitmap mode performance hit doesn’t seem noticeable for my use cases, especially with the integrity data on the SSDs. I’m able to schedule periodic scrubs to validate my data, and presumably it should auto-repair bitrot assuming one of the mirrored disks has a valid checksum match (I haven’t had any mismatches thus far though, so I’ve never put that to the test).
The problem comes in when I’m trying to replace drives. For example, if I try to pvmove a PV to another, empty PV, it returns an error saying that’s not supported with integrity enabled. I have to first disable integrity and then pvmove.
Doesn’t this kind of defeat the point? It’s introducing a period when I’m not tracking data integrity. I would’ve thought I should be able to replace a an old/bad disk with integrity active, especially with the volume being raid1.
Does anyone have experience using a similar setup? If so, do you have any tips/suggestions on how to replace disks?
