Hey Guys,
So I’m using oVirt to create a brick and then add a cache to the LVM after.
I’m doing the folllowing commands but i’m not seeing an improvement on my benchmarks.
pvcreate /dev/md/VMStorageHot_0
vgextend RHGS_vg_VMStorage /dev/md/VMStorageHot_0
lvcreate -L 1500G -n lv_cache RHGS_vg_VMStorage /dev/md/VMStorageHot_0
lvcreate -L 100M -n lv_cache_meta RHGS_vg_VMStorage /dev/md/VMStorageHot_0
lvconvert --type cache-pool --cachemode writeback --poolmetadata RHGS_vg_VMStorage/lv_cache_meta RHGS_vg_VMStorage/lv_cache
lvconvert --type cache --cachepool RHGS_vg_VMStorage/lv_cache RHGS_vg_VMStorage/VMStorage_lv_pool
Okay, first thing’s first: what benchmarks are you trying to see improvements on? What are your realistic expectations?
What is your physical storage setup?
The cold pool is 5 HDD’s in Raid6 with a 65kib chunk size.
The hot pool is 4 SSD’s in Raid10 with a 512kib chunk size.
On the hot pool using dd i’ll get around 250MB/s and on the cold I get 40MB/s. When adding the cache I still get 40MB/s.
The benchmark i’m using is
time dd if=/dev/zero of=/gluster-bricks/VMStorage/test bs=1M count=1000 oflag=direct
Robert4049:
gluster-bricks
Ah, gluster. Didn’t realize that’s what you’re using.
I have no experience with gluster, but O_DIRECT is a very cache-unfriendly operation type. Lots of tiered storage solutions do not support O_DIRECT going into the cache.
Using DD, you’re doing sequential writes. DD on sequential writes to rust should net you closer to 100-150MB/s on a single drive. RAID6 should get you slightly higher performance than that, but not by much. (RAID5/6/7 sucks for performance)
I think what’s happening is LVM is ignoring the cache due to O_DIRECT and is sending it straight to the rust. Gluster is also likely killing some of your performance.
See what happens if you do:
dd if=/dev/zero of=/gluster-blocks/VMStorage/test-2 bs=4M count=1000 oflag=direct
#AND
dd if=/dev/zero of=/gluster-blocks/VMStorage/test-3 bs=4M count=1000
Larger blocks might be required. In addition, I’d like to see if my O_DIRECT suspicion is correct.
[root@131-STR-02 VMStorage]# dd if=/dev/zero of=/gluster-bricks/VMStorage/test-2 bs=4M count=1000 oflag=direct
1000+0 records in
1000+0 records out
4194304000 bytes (4.2 GB) copied, 75.6966 s, 55.4 MB/s
[root@131-STR-02 VMStorage]# dd if=/dev/zero of=/gluster-bricks/VMStorage/test-3 bs=4M count=1000
1000+0 records in
1000+0 records out
4194304000 bytes (4.2 GB) copied, 1.94241 s, 2.2 GB/s
nx2l:
lvs -a -o+cache_mode
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert CacheMode
VMStorage_lv RHGS_vg_VMStorage Vwi-aot--- <21.82t VMStorage_lv_pool 0.04
VMStorage_lv_pool RHGS_vg_VMStorage twi-aot--- 21.80t 0.04 0.25
[VMStorage_lv_pool_tdata] RHGS_vg_VMStorage Cwi-aoC--- 21.80t [lv_cache] [VMStorage_lv_pool_tdata_corig] 0.36 7.78 25.33 writeback
[VMStorage_lv_pool_tdata_corig] RHGS_vg_VMStorage owi-aoC--- 21.80t
[VMStorage_lv_pool_tmeta] RHGS_vg_VMStorage ewi-ao---- 15.81g
[lv_cache] RHGS_vg_VMStorage Cwi---C--- 1.46t 0.36 7.78 25.33 writeback
[lv_cache_cdata] RHGS_vg_VMStorage Cwi-ao---- 1.46t
[lv_cache_cmeta] RHGS_vg_VMStorage ewi-ao---- 100.00m
[lvol0_pmspare] RHGS_vg_VMStorage ewi------- 15.81g
home onn Vwi-aotz-- 1.00g pool00 4.79
[lvol0_pmspare] onn ewi------- 232.00m
ovirt-node-ng-4.3.4-0.20190610.0 onn Vwi---tz-k <426.27g pool00 root
ovirt-node-ng-4.3.4-0.20190610.0+1 onn Vwi-aotz-- <426.27g pool00 ovirt-node-ng-4.3.4-0.20190610.0 2.07
pool00 onn twi-aotz-- <453.27g 2.56 2.35
[pool00_tdata] onn Twi-ao---- <453.27g
[pool00_tmeta] onn ewi-ao---- 1.00g
root onn Vri---tz-k <426.27g pool00
swap onn -wi-ao---- 4.00g
tmp onn Vwi-aotz-- 1.00g pool00 4.93
var onn Vwi-aotz-- 15.00g pool00 3.73
var_crash onn Vwi-aotz-- 10.00g pool00 2.86
var_log onn Vwi-aotz-- 8.00g pool00 4.41
var_log_audit onn Vwi-aotz-- 2.00g pool00 5.23
nx2l
June 27, 2019, 9:09am
10
Is the md device still building?
nx2l
June 27, 2019, 11:37am
11
It would also be worthwhile to do a few write tests while saving iostat output so you can analyze it later.
The slow cache is still building,
The hot has finished.
I also ran the benchmark this morning and these were the results.
nx2l
June 27, 2019, 4:31pm
13
run it again but capture the output of iostat while it runs
Here’s the output from the Storage Nodes themselves
nx2l
June 28, 2019, 8:32pm
16
You need to watch the values while you are running your benchmark tests
