I installed lutris with the command sudo pacman -S lutris but when I launch it via terminal I get this error message and lutris never loads. I thought maybe it was related to not having python installed because some of the error messages have .py at the end so i installed python but it didn’t change anything.
Any suggestions?
well first of all which python did you install, 2 or 3. As far as I know Lutris requires 3.
And also copy&paste from Lutris discord:
PSA: Arch updated Lutris in the last 24 hours you may now get an error when launching the states lxml is not found.
Until the arch package adds it to the required dependencies, you could fix this yourself by installing
python-lxml
there is currently a bug report open about it on the bug tracker so with any luck it will bevfixed very soon
