LSI 9500-8i HBA not detecting any Disks
Recently I got a few SAS SSDs, to be able to use them I got an HBA and bought a used 9500-8i.
The Problem is, I can not get the HBA to detect any Disks.
I installed the latest firmware,bios. I tried 3 cables. I tried 4 differrent SAS/SATA drive Models. My backplane is working with the sata ports of my mainboard connected through a sata reverse cable. The drive just gets very hot while inserted, so it draws a lot of power. I went through all Bios Settings, disabled all CSM Options.
I don’t know what else I can do.
CLI Version = 007.3603.0000.0000 Oct 30, 2025
Operating system = Linux 7.0.12-1-pve
Controller = 0
Status = Success
Description = None
Basics :
Controller = 0
Adapter Type =   SAS3808(A0)
Model = HBA 9500-8i
Serial Number = SKBREDACTED
Current System Date/time = 06/23/2026 16:04:54
Concurrent commands supported = 4864
SAS Address =  500062b208484b80
PCI Address = 00:2b:00:00
Version :
Firmware Package Build = 38.00.00.00
Firmware Version = 38.00.00.00
Bios Version = 09.75.00.00_38.00.00.00
NVDATA Version = 38.00.00.10
PSOC FW Version = 0x003D
PSOC Part Number = 14790
Driver Name = mpt3sas
Driver Version = 54.100.00.00
PCI Version :
Vendor Id = 0x1000
Device Id = 0xE6
SubVendor Id = 0x1000
SubDevice Id = 0x4060
Host Interface = PCIE
Device Interface = PCIe-16GT/s
Bus Number = 43
Device Number = 0
Function Number = 0
Domain ID = 0
Pending Images in Flash :
Image name = No pending images
Status :
Controller has booted into certificate provision mode = No
Package Stamp Mismatch = No
Supported Adapter Operations :
Support more than 8 Phys = Yes
Support Enclosure Enumeration = Yes
Support Allowed Operations = Yes
Support Multipath = Yes
Support Security = Yes
support EKM = No
Support Secure Boot = Yes
Support Platform Security = No
Support Package Stamp Mismatch Reporting = Yes
Support PSOC Update = Yes
Support PSOC Part Information = Yes
Support PSOC Version Information = Yes
Supported PD Operations :
Support Physical Link Speed = Yes
HwCfg :
ChipRevision =  A0
BatteryFRU = N/A
Front End Port Count = 1
Backend Port Count = 11
Serial Debugger = Absent
NVRAM Size = 0KB
Flash Size = 16MB
Temperature Sensor for ROC = Present
Temperature Sensor for Controller = Absent
ROC temperature(Degree Celsius) = 43
Boot :
Max Drives to Spinup at One Time = 2
Maximum number of direct attached drives to spin up in 1 min = 60
Delay Among Spinup Groups (sec) = 2
Capabilities :
Supported Drives = SAS, SATA, NVMe
Enable JBOD = Yes
Max Parallel Commands = 4864
Max SGE Count = 128
Max Data Transfer Size = 32 sectors
Secure Boot :
Secure Boot Enabled = Yes
Controller in Soft Secure Mode = No
Controller in Hard Secure Mode = Yes
Key Update Pending = No
Remaining Secure Boot Key Slots = 7
Security Protocol properties :
Security Protocol = None
I made some Posts about my Serverupdate at Mastodon.
You cannot mix SATA and SAS drives. That means you may need a 2nd HBA to separate both.
I didn’t mix them. My sata HDDs are connected to the mainboards sata port through a sata reverse cable.
In my first attempt I tried my HBA with all SAS drives. After that I only tried with one drive at a time, one time trying a single sata ssd on the hba.
It’s possible the mobo is battling you. I’ve heard of issues where some HBA cards force you to disable your SATA ports entirely.
If you go into motherboard UEFI, does the HBA’s menu (UEFI driver control) show up? and if so does it show the drives connected to it?
The HBA shows up in the BIOS but says 0 Drives there as well
I also tried disabling all legacy CSM options but apart from that the bios settings are very much default.
  • Can you test the HBA with drives directly attached to it?
  • Can you give the exact cable SKUs you used to connect the HBA to the backplane?
  • Is it known if the HBA is a genuine first-party Broadcom model or a third-party compatible model?
I used these cables for the Backplane, I don’t have other direct cables. I could buy some.
0.5m 24G Internal SlimSAS SFF-8654 to SFF-8654 8i cable, Standard Profile Straight to Low Profile Straight, PCIe 4.0, 85 ohm 30AWG, without sidebands
These are 2 cables, one 40cm and a 50cm
FUJITSU SAS-Cable / Datenkabel (40cm) - SFF-8643 zu SFF-8654-8i - PRIMERGY RX4770 M4 - A3C40202283
The HBA was bought used and is made by Broadcom. I think it’s a legitimate card since I could flash its firmware through storcli64 and the pcb, cooler and packaging look genuine.
I bought another HBA this week, a SuperMicro AOC-S3816L-L16it and hope it works better. If it doesn’t work. I’ll probably get another set of direct cables for testing or I might buy a 9306-24i which has the same SFF8654 Ports as my current HBAs but run on the old pre 9400 architecture which might have better compatibility.
hmmm… I just looked at the actual pictures and it looks like the case has one of those UBM setups which complicates it’s compatibility with HBAs.
As a baseline I’d try plugging the minisas hd connector comming off of the HBA into the topmost port on the top most backplane and then try inserting a drive into one of the top 4 slots in the front of the case and see if the HBA identifies it.
Thanks for the info. I also tried to look for firmwares for the arm chip on the Backplane but I couldn’t find much about it.
I will try the port again when I’m back at my server. I don’t have my Server at home. Hopefully the other HBA arrives until then.
what CLI command is this output from? Can you tell it to list the drives it knows about? Is there an option ROM you can enter to see the drives from there? could it be something like the HBA thinks the drives are foreign and you have to tell it they are ok?
The output was from /c0 show all if I remember correctly. I think I could boot the efi of the card but I don’t think it’ll change much or what I could do there since the card shows 0 drives in the uefi of the mainboard as well. I don’t know where I could find anything about the foreign drives but I would expect it to also get listed in the show command.
I also bought a usb to sas adapter to individually test the drives but they should work, the seller tested them. The Kioxia PM6 are also on broadcoms list of compatible drives Compatible SAS Drives – KIOXIA. They’re also listed with 22.5g, I wonder about the ssd speeds when I get the HBA running because Broadcom lists the sas ports as 12g for the 9500-8i
Did you say you had tried a known, good sata drive, in a backplane bay connected to the hba?
Yes, the sata ssd is one I was using on several devices, it’s a crucial MX500 1tb
Oh no, I also acquired an 9500-8i, I thought it was tri-mode and that it meant you could mix, but that’s not the case? I’m new to this kind of hardware…
Edit: are you sure that: the tri mode cards cannot mix sata and sas?
the older LSI cards can, before NVMe entered the mix…
I thought tri mode, and other cards, could mix sata and SAS drives
I have very old hba’s that can mix SAS and sata
I plugged in my SATA HDDs (Toshiba MG08) into the HBA and they don’t show up either. There are No Sata disks connected to the mainboard. only my boot nvme. These HDDs were working without Issues in the backplane with sata reverse cables to the motherboard. I only swapped the cable to the HBA
root@pve:~# storcli64 /c0/eall/sall show all
Controller = 0
Status = Success
Description = No drive found!
The Supermicro HBA arrived and I tried it, it doesn’t have the trimode firmware, it is running the SATA_SAS Firmware but still it doesn’t find any drives ):
root@pve:~# /opt/MegaRAID/storcli/storcli64 /c0 show all
Controller = 0
Status = Success
Description = None
Basics :
Controller = 0
Adapter Type =   SAS3816(A0)
Model = SAS3816
Serial Number = NA
Current System Date/time = 07/04/2026 12:21:41
Concurrent commands supported = 6784
SAS Address =  50030480254f4ff0
Version :
Firmware Package Build = 25.00.00.01
Firmware Version = 25.00.00.00
Bios Version = 09.49.00.00_25.00.00.00
NVDATA Version = 25.02.00.12
PCI Version :
Vendor Id = 0x1000
Device Id = 0xE6
SubVendor Id = 0x15D9
SubDevice Id = 0x1B65
Device Interface = SAS-12G
Bus Number = 43
Device Number = 0
Function Number = 0
Domain ID = 0
Status :
support EKM = No
Support PSOC Update = No
Support PSOC Part Information = No
Support PSOC Version Information = No
HwCfg :
ChipRevision =  A0
BatteryFRU = N/A
Backend Port Count = 21
NVRAM Size = 0KB
Flash Size = 16MB
ROC temperature(Degree Celsius) = 48
Boot :
Capabilities :
Enable JBOD = Yes
Max Parallel Commands = 6784
Max SGE Count = 128
Secure Boot :
Remaining Secure Boot Key Slots = 6
I tested some SAS SSDs with a USB to SAS Adapter and they do show up with that on my pc, so the sas drives aren’t faulty either.
I created an Account at alibaba to contact the seller about the compatability.
They said the Arm chip on the Backplane is not UBM but SGPIO and they said the chassis backplane is a straight-through backplane, and it does not have any compatibility issues.
I may try to get an old LSI 9305 HBA then ):
