I am planning to use this build: http://pcpartpicker.com/p/2slwd but the only problem is I am not sure about the case being able to hold a low profile Radeon 7850 low profile GPU.
If anyone could help me out with this I would be grateful. Thanks
If you mean a low profile 7850 card like this > http://www.afox-corp.com/en/products_details.asp?proid=209 then yes it will fit. It will get hot in there though. Plus that included psu is a unit I dont have too much faith in to run a gpu.
I would personally stick with the crossfire ability of the apu and discrete gpu in such a small case here is a review to read http://hexus.net/tech/reviews/cpu/46157-amd-a10-5800k-dual-graphics-evaluation/
There are more options for cheap low profile 6670's - cost next to nothing.
Going for a card such as a 7850 you will lose all that is gained by having fast ram.
You could just grab a case like this http://pcpartpicker.com/part/cooler-master-case-rc120akkn1 and use whatever gpu and psu you like.
Thank you appreciate it ! I really want to stick to this case because I want a console like pc that will eventually run steam OS
Another quick question: would this non low profile 6670 fit into that case ?
