Low power but big capacity
Hi All,
my concept is not ready yet, because I try smth, that I didnt do yet. Maybe you can give me some guidance.
I would like to build a NAS with low power consumption with a raspberry pi 5 but also capable of accessing 3,5" HDDs. Longterm I want to use it as a cloud storage. Also I dont have the money to buy 500+ NAS systems.
The idea is to get the Pi 5 with the active cooler, a HAT from aliexpress connected via the PCIe. Which contains SATA ports and a molex out. This needs an external power supply of 12V and around 8Watts for each HDD. But its not bootable. The OS runs from USB-A from a 2,5" SSD which is connected via SATA to USB adapter. The Pi has its own power supply via classic USB-C.
I didnt search for an OS yet.
Also I would like to run FANs with a PWM controller. I think I can control it with secific PINs on the Pi.
things I own:
Fractal Node 804 + FANS (a lot)
trash SSD (180/128GB)
tools, soldering iron
products mentioned:
Geekworm x1009 PCIE zu 5-Port Sata Shield
Delock USB to SATA 6 Gb/s Converter with USB Type-C or USB Type-A connector
greetings from germany
Sounds like you want to DIY an Odroid HC4 :wink:
If you need more HDDs and faster network, the Odroid H4+ is worth considering.
Those pci-e shields and usb converters are going to cost power, just like those fans will, i would remove all except 1 to set low and blow over the hard drives.
A second hand intel system would probably do best, something like an 8th gen i3 with one of the more efficient motherboards i’ve seen reach a couple of watts, but way more power than a raspberry pi.
Have look at this german thread
I know the raspberry pi will idle at about 3W, but if you add pci-e adapters and usb adapters that will rise and might stop some power management features to stop working.
The RPi 5 or any RPi is far from ideal for the task, you’re much better off with a Rockchip SoC board.
If you want ARM,
SBC:
RockPro64 ( ROCKPro64 4GB Single Board Computer - PINE STORE )
Large heatsink:
ROCKPro64 30mm Tall Profile Heatsink - PINE STORE (you’ll still need some kind of airflow during full load)
Controller:
ASMedia ASM1166 based board (I’ve tried the Silverstonetek ECS06 but I don’t see why for example this wouldn’t work, GLOTRENDS SA3026 6 Ports PCIe X4 SATA Erweiterungskarte, inklusive SATA Kabel und 1:5 SATA Splitter Stromkabel, Kompatibel mit Windows,Linux,Mac OS,NAS: Amazon.de: Computer & Zubehör )
MicroSD card:
SanDisk MAX ENDURANCE Video Monitoring for Dashcams & Home Monitoring 32 GB microSDHC Memory Card + SD Adaptor 15,000 Hours Endurance, White: Amazon.de: Computer & Zubehör to boot from
PSU: Anything will do pretty much
ATX breakout board, there are a bunch available on amazon.de etc, I’ve used one that looked like this just fine: Fused 24/20-pin ATX DC Power Supply Breakout Board — PMD Way
Power the SBC of the 12V rail and just hook up the HDDs.
OS: Whatever you prefer, RockPro64 have good overall support both running FreeBSD and most common Linux dists. I would advice against newer SoCs due to support.
It’s not the fastest or best SoC around but the SoC and board have good support overall which isn’t necessarily common.
…otherwise I’d just go for the Odroid H4+ (I believe pollin.de sells odroid models in .de if you want to buy locally)
Might aswell tag @ThatGuyB if he wants to add something
Welcome to the forum!
What kind of capacity are you looking for? 10 / 20 / 60TB? Or are you ok with 4 TB? What are you going to store? Does your NAS need to always be online?
These are a few questions to think about. As far as the rpi 5, I wouldn’t trust it as a NAS. It’s fine as a desktop, but the amount of headaches you need to go through with it, like adapters and breakout boards, it’s not worth it. Besides, the rpi 5 is expensive for what it offers (if you’re in for the automation around it, using sensors and other HATs or accessories, then stick to the rpi ecosystem, however, if all you need is a NAS, then look for other boards).
The H4+ or H4 Ultra is what I’d recommend, however, idk what you’re planning to run on the NAS either. Are you just looking for a Samba and / or NFS server and that’s it? If so, a RockPro64 with an external PSU should do. If you plan to run more things, like, idk jellyfin or something, look into the H4+.
But then the question about power and storage comes back. If you only need 4 to 8 TB of space, grab either 4x 4TB plain ol’ sata SSDs and something like a H4 or H4+. It’ll have really low power consumption and decent specs to make use of the SSDs and still allow you to run other stuff on it.
If you need bulk storage and don’t care for power consumption and performance, the rockpro64 already mentioned is decent. It’ll make full use of a couple of 3.5" spinning rust in stripped mirrors and serve as a NAS and not much else, unless you run pretty minimal software. But with spinning rust, you’ll use quite a bit more power (my rockpro64 with 2x 10TB HDDs draws about 20W or so - yes, I think 20W is a lot, compared to how low you can get with SSDs).
Check out Wolfgang’s channel. He’s made a name for himself doing just that. He offers links to valuable resources with data that help making personal decisions.
I even think he has a parallel channel in German :slight_smile:
correction: h4+ or h4 ultra (since the h4 base doesn’t have any sata ports on it)
Given pricing of large SATA SSDs you’d actually be better off getting the H4+, M.2 4×1 Card – ODROID + NVME based ones.
https://www.idealo.de/preisvergleich/OffersOfProduct/202023801_-p3-plus-4tb-crucial.html
https://www.idealo.de/preisvergleich/OffersOfProduct/202070652_-black-sn850x-4tb-western-digital.html
vs
https://www.idealo.de/preisvergleich/OffersOfProduct/204126809_-bx500-2-5-4tb-crucial.html
https://www.idealo.de/preisvergleich/OffersOfProduct/202928265_-ultra-3d-4tb-sdssdh3-4t00-g26-sandisk.html
(I’ve taken the cheaper ones for each interface)
Oh wow,
yeah thats why I’m here for :slight_smile:
The second option is really interesting. I will look into it.
Thank you
The thread looks really interesting. I also tought about Pi for learning purposes. Because it could get important in the future, when I want to set up aquisition systems for data collecting and uploading.
But this is all long long term.
Actually a low power x86 secondhand system would be my plan B, but I dont have experience with system builds below 500W. I will check it out to model learn from it. :slight_smile:
thank you
this is really helpful!
Theses boards really look like what I had in mind.
Now I need to choose if I want a all in one solution or build something like this. :slight_smile:
thank you
I have some up to 4TB 3,5"HDDs left over since I moved from an ATX case to a µATX one.
Right now an easier solution to set up would be better, I really consider the ODROIDs. The system will be idling most of the day. When I am home from work I want to access it form the livingroom to stream media or do some file management with desktop to notebook.
In the future I just want to have a dropbox for me and maybe my gf or friends. But for now I have cloudstorage right now, that I dont need to pay.
the capacity doesn’t really matter right now, I just wanted to make use of my HDDs from the cupboard.
but I want it to be 3,5"HDD to have the potential to grow into a mediastorage with the years. (digitizing my CDs or BDs)
thank you for the guidance,
I appreciate it
I subscribed already :slight_smile: and I will check it out on the public transport.
