Hi everyone.
I’m looking for an advice on how to setup my guest OS and VM for best low latency audio.
I run Windows 11 Pro VM in the virt-manager for my professional work on a Fedora Workstation 44 with the following specs:
Summary
Report details
Hardware Information:
Hardware Model: ASUS TUF GAMING B550M-PLUS
Memory: 32.0 GiB
Processor: AMD Ryzen™ 9 5950X × 32
Graphics: Intel® Arc™ A750 Graphics (DG2)
Disk Capacity: 6.8 TB (/root on separate SSD, /home on the mirror on 2 SATA SSDs)
Software Information:
Firmware Version: 3611
OS Name: Fedora Linux 44 (Workstation Edition)
OS Build: (null)
OS Type: 64-bit
GNOME Version: 50
Windowing System: Wayland
Kernel Version: Linux 7.1.8-200.fc44.x86_64
The problem is that the audio in my VM is choppy/laggy for MS Teams calls. To conquer this I have tried already:
CPU core pinning
Setting Pipewire as the backend for VM’s audio
Passing my USB headset (JABRA EVOLVE 20) via SPICE and USB passthrough
Many other advises from the internet, e.g., changing USB controller protocol or Audio device type, etc.
Things I haven’t tried yet are:
Using Teams on the host for calls - I’d like to keep all stuff relevant to the job in the VM
Using the Scream protocol to bridge audio between host and guest via network protocol. Seems to me as a complication, thus did not try yet.
How do you get low-latency audio in similar situations ? I’d appreciate if somebody could share a working recipe.
Thank you for your time.
ArtūrasB.
