Alright so, I messed up. I used StoreMI to try and speed my HDD up by caching frequently used stuff onto the SSD but, after realizing that it wasn’t all that much faster, I deleted the tier StoreMI made and my HDD got formatted.
As I was deleting the tier, StoreMI did warn me that 200GB of files will be deleted but, instead, it formatted my entire HDD and now I can’t access about 2.8TB of data.
Is there any way to just re-attach the drive and get it back or, will I have to get a recovery software and get the files that way?
You can use software like Recuva to recover files. If you have windows installed on another hard drive.
Best of luck.
PS. I added two tags to your post, so if you get a notification about me editing your post, that is why. I added the #helpdesk and #data-recovery tags.
