So my laptop is about 2 1/2 years old so I was looking to get some small upgrades for it.
(My laptop is a HP Pavilion G7 running Windows 10, please let me know if you need more info on it)
First the battery. My current one is a 10.8v, 4300 mAh battery and I was looking for a good upgrade on this. I found this one, will it fit/work for my laptop, and would it be a significant improvement on the battery? If not, could you please recommend one?
http://www.newegg.com/Product/Product.aspx?Item=9SIA3E41EY6571
Second, I would like to go from a HDD (or whatever its called) to a SSD. Would this one fit/work inside my laptop?
http://www.amazon.com/Samsung-2-5-Inch-Internal-MZ-75E500B-AM/dp/B00OBRE5UE/ref=lp_1292116011_1_2?s=pc&ie=UTF8&qid=1445051300&sr=1-2 Is there anything faster/better I could get for near the same price?
I was mainly wanting to get a SSD for the better performance of my laptop, but would it also increase my battery life a little bit?
Thanks to anyone who takes the time to help me, I really appreciate it.
