I have setup a KVM win10 guest with gpu passthrough, as well as looking glass with IVSHMEM Device driver.
In fact it functioned well a few month ago. But when I tried to launch it recently looking glass host failed to start. The error message in looking-glass-host is quite clear:
[I] 435396798 app.c:771 | app_main | Looking Glass Host (B6)
[I] 435397196 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 7 5700G with Radeon Graphics
[I] 435397594 cpuinfo.c:38 | lgDebugCPU | CPU: 1 sockets, 8 cores, 8 threads
[I] 435399688 ivshmem.c:132 | ivshmemInit | IVSHMEM 0* on bus 0x3, device 0x1, function 0x0
435401944 [E] ivshmem.c:214 | ivshmemOpen | DeviceIoControl Failed: 0x00000224 (An attempt was made to attach to a device that was already attached to another device.)
[E] 435402565 app.c:783 | app_main | Failed to open the IVSHMEM device
It points out that my IVSHMEM device has already been attached to another device. But I am now stuck here with no clue how to solve this. I am connecting to the guest VM via RDP, but I don’ t think this is causing the problem because last time when looking glass worked I was also connecting via RDP.
Trying to run looking glass guest would stuck at starting session after successfully handshaking with the host:
[I] 17262411821 main.c:1566 | lg_run | Guest Information:
[I] 17262411837 main.c:1567 | lg_run | Version : B6
[I] 17262411841 main.c:1588 | lg_run | UUID : 54e36575-f3d6-45fb-8329-0c776ee4318c
[I] 17262411846 main.c:1597 | lg_run | CPU Model: AMD Ryzen 7 5700G with Radeon Graphics
[I] 17262411850 main.c:1598 | lg_run | CPU : 1 sockets, 8 cores, 8 threads
[I] 17262411852 main.c:1600 | lg_run | Using : DXGI Direct3D 11
[I] 17262411854 main.c:1636 | lg_run | OS : Windows
[I] 17262411855 main.c:1638 | lg_run | OS Name : Windows 10 Pro (Build: 19045)
[I] 17262411858 main.c:1660 | lg_run | Starting session
