Hello,
I have quite crazy idea and I reference to https://forum.level1techs.com/t/looking-glass-triage/130952/1392
I don’t know how technically it is possible, but I think there are some companies which can build “custom” PCI card.
Idea is that we had custom Looking Glass PCI card, which would have HDMI IN (for example), some small memory for saving current frame and chip which would take frame from HDMI IN and save it into memory, then host GPU would just display it.
I know there are capture cards out there, but they are proprietary and they works mostly only with proprietary software, I mean this like push Looking Glass into next level
I would pay for it.
Advantage of it, is that you don’t have to care about capturing frames on host, you can just focus on displaying it.
I know it is really stupid idea, but I would like to listen opinions, maybe it is not possible to create custom PCI card (maybe because it is really expensive), I don’t know.
