The router OS matters not to the APs & mesh. The router is the router. The APs handle wifi.
For mesh wifi you can go either controller based (makes managing multiple APs easier) or stand alone as long as they have mesh ability baked into them.
Lots of choices for either path.
You have to do the research.
One thing to beware of, is some WAPs require some kind of controller (hardware or software) in place to work.
I recently picked up a (WIFI6) TP-Link EAP610 specifically because it has a standalone mode so I don’t need to fuss around with a hardware controller of docker container. Supposedly it can do mesh connections, but I only have 1 and have never messed around with that sort of setup.
i’m currently considering TP-Link EAP773, and since you own one, I’m just wondering if seamless roaming will work with different models, but same brand (i.e. another Omada AP)?
I’m planning on getting 1 AP for the time being. And would that be enough for a 3500 sqft home?
LOL I did notice how lightweight it is when my CPU usage was pretty low after doing pcie_acs_override and PCie passthrough. Makes me wonder how much I’d have been able to push my Jellycloud if OPNsense was also in there…
The total usage of my jellycloud server, Proxmox server, & 2.5Gb Mikrotik switch is around 150W at idle (according to my 1kW UPS)
Yes you should be okay perf wise, but unless space and power are critical considerations, I would go with modular approach and not cohost router and app server at the same device.
Its cleaner and more reliable to have separate host for each functionality. Same idea as all-in router+switch+ap vs separate router, switch and APs.
Imagine misbehaved app choking your all-in-appliance and hosing you entire home network by accident.
yea that crossed my mind. I was play pros/cons with myself for months. Only reason why I stopped was because my cousin was selling his old PC for about $150 (CPU & mobo). Figured I should go right ahead and snag it.
