Hi, for the time being my laptop’s display is no more and I’m looking for a temporary replacement/extension.
First of all, I’m looking for your personal experiences and thoughts. Maybe there’s something I haven’t considered yet?
Amazon’s listing is full of no name Chinese “brands”. I’m fine with this, if these cheap offers (60-80€) aren’t actually atrocious. I’ll be using the portable monitor a lot for commute, so my first model must be either cheap or well protected (extra case => more space
). I don’t wanna be sad if an expensive one breaks.
Hardware: laptop with 1x HDMI, 1x Type C alt mode DP (not Thunderbolt, no USB-PD).
Priorities, roughly in order:
- Type C DP
- Great PWM or DC dimming (I generally prefer lower brightness)
- 15.6” size (my laptop is 15.6 and I’m used to it. Not sure if going smaller is tolerable?)
- a basic stand?
- matte
- HDMI? Just to make it easier to connect any 2 external monitors I might encounter (one over HDMI, one DP) - doesn’t HDMI need a separate power source?
I don’t care about color or viewing angles, so long they aren’t awful.
Touch and battery? I also have a Samsung DeX capable phone, but is it worth the price premium? I’m not sure.
Don’t want: speakers or analog audio out.
I have seen the cheapest models start at like 60€, are they usable or belong in the trash? Then there are people selling them used for 45€, not few in number. Are there widespread problems with the displays or do people just try a bunch of them at once or use them for a while and then put up for sale?
I’m gravitating towards buying one of those cheapest displays. Simply to not care about breaking an otherwise expensive toy.
Thanks
