I have a PNY blower style 1080ti. I would like to put an open air cooler on it. Is there any vendor that sells coolers. I think its a reference board design. I am not sure where to look. I don’t want to water cool because I want the lest amount factors in the system this is in to go wrong as I need it always running with little maintenance. Here is the gpu vendor specs VCGGTX1080T11PB-CG2
this should fit. it is large about 2.5 slots so buyer be ware.
There’s also the Morpheus Core II. Have to put your own fans on it, but 2 120mm Noctuas like the NF-A12x25 should make it a rediculously cool and quiet card. https://www.newegg.com/Product/Product.aspx?Item=2T3-0007-00004
Thank you guys, I will check these out
