I have purchased a Core i7-3770 as an upgrade to this system and I am looking for a new cooler for less than $50 brand new from Amazon. My requirements for a cooler:
Air cooling only. I don’t want to be dealing with leaks.
Should have compatibility with the newest platforms (AM4, AM5, LGA1700 etc.) so I don’t have to throw it away when I want to upgrade the entire platform
The Peerless Assassin is bulky and really light for it’s size so I wouldn’t recommend it as it may cause issues further down the road with clearance etc.
psst check out the physical dimensions of the p-a-c…
Model Number: SCMG 5200
Dimensions: W 136.0 x D 109.5 x H 154.5 mm
Weight: 900 g / 31.7 oz
where as the thermalright, measures 110mm in width, 155mm in height, 125mm in depth, and it weighs 730g.
so claiming it will be bulky in comparison when its literally 20% less massive.
while being 1mm wider, and higher.
and no i wont cause issues with clearance later.
oh yeah and its also half the price while it gives comparable cooling.
Depth is where you may run into issues, also you want mass because that allows better cooling in general. I’m also not sure why you’re linking to Amazon.co.uk when stated target price is in USD. In addition I don’t see why you’d want more fans than necessary. Guess I’m getting old and practical
Thermalright is the go to for budget air coolers and their fans are actually decent performers for being cheaper fans. Although I’ve heard there was recently a new revision of the fans, so watch out for that.
I picked up a 6-pipe single tower Burst Assassin with nickle cold plate for $23 on sale. It keeps my 13400f below 50C at max draw and I plan on upgrading to a 14th gen i5/i7 using the same cooler.
If height is NOT much a concern- Darkrock4 can be an absolute brute
[*pending on when made, may need to request newer socket support bits, from beQuiet]
Other viable options being
Sycthe Mugen [Rev. C now more readily available]
Sycthe Fuma 3 [V2 is also V. Good]
Deepcool AG620 / AK620
Thermalright Peerless 120
If space should become a limitation, towards any future build
Thermalrights AX120-X67* may do VERY well, to its OV sizing [see image below]
*will support to LGA1700 natively; AM4 for sure, but don’t recall if AM5 ready
Thermalrights AX90 series also viable [+full Cu variant option], if concerned on RAM height
Most overbuilt Downdraft Heatsink, would be Noctuas C14S [at 115mm height]
