Hello
I'm working on installing IP CCTV system in a hotel we have here, I usually use Synology for most of my installations just because the user/clint side of the GUI its beautiful it also have Android, IOS and Desktop applications with a very easy and beautiful GUI for your grandma average user.
But this is my first large scale installation
I need to install 35 POE IP camera with the ability to scale up to 100, maybe I can compromise at 75.
I want to view / record at 1080p with at least 24fps.
So I was looking at synology stuff with there NVR calculator
and I found few but they are kinda expensive, so I thought to look around for an NVR OS or Distor and Maybe I can build my own NVR, with better hardware and cost me less money.
I found https://zoneminder.com So I was planning on running it on top of a freenas on a VM and just to get ZFS and more redundancy.
But then I saw the GUI and the lack of android/IOS application and how its kinda unpolished from client side and I hit the brakes on this one, I don't think the end user will appreciate how much work I have done if his side is not "pretty enough" for him.
I also checked Unifi Solution and I love it but there is no unifi distributor in my county and I have to ship everything and that will probably cost me more than synology.
So I'm here asking for advice what do you think I should do? should I stick with Synology and just suck up the cost? or is there another solution out there i don't know about? or is there a way to make zoneminder better on client side ?
