Hi there,
I'm currently going through the process of beginning my first PC build, which can be viewed here: http://pcpartpicker.com/p/hggQBm
I realized that the motherboard that I chose does not have Wireless Network capability built in, so I was wondering if you had any recommendations for buying Wireless Network Adapters, preferably one that offers the most value for the money.
Thank you!
What kind of router do you have? Wireless N, AC or maybe even B? Depending on that we can choose one. Also are you ok with a pcie wireless card? It uses up a pcie slot but is generally more stable and less laggy vs a usb adapter.
I have a Wireless N router and I would prefer using a PCIE wireless card over an usb adapter. I hope that helps!
Sorry for the response time, counter strike go figure xD. I actually just ordered this one for myself as my Asus unit's 5ghz capabilities just died. http://www.amazon.com/dp/B00HF8K0O6/?tag=pcpapi-20 $30 and you have the ability to upgrade to 5ghz Wireless AC, although you can still use it for 2.4ghz wireless N no problem. It comes with an intel wireless chip so it should be ultra reliable and fast. It also is bluetooth 4.0 compatible as an added bonus :D
