Hi everyone!
I’m searching for a large (10ports+) 3.1 Gen 2 hub. This one comes close:
https://www.amazon.com.au/dp/B07SWW7MNG/ref=cm_sw_r_cp_api_i_JdOgDb6T50F8H
But only supports 3.0 speed. It needs to have a type C connector but having trouble finding a true 3.1 hub
What does “large” mean? (port count wise?)
Any other features needed (clamp, indicator lights, switches on the ports, etc.)?
Use case would also be helpful.
A suggestion:
Another: 10 Port with external power adapter.
https://www.silverstonetek.com/product.php?pid=818&area=en
I’ve edited my post. I keep forgetting USB 3.0 is now 3.1 Gen 1 lol
The naming is… a clusterfuck.
Table about USB3.x from here
So you are looking for USB3.2 Gen2 with USB-C, right?
For what exactly?
Hate to be a Debbie Downer, but I don’t think that what you’re looking for really exists yet. I found a ridiculous piece of enterprise grade gear that almost matches what you describe but It’s almost $2000, it’s rackmount, it only supplies 5gb/s per port and it requires a thunderbolt interface.
I was starting to suspect that
Future proofing, Multiple Portalble SSDs with video media files, cable management
