The closest I could find is Corsair Carbide 400C Compact measuring 8.46 x 16.74 x 18.26 in
Is there anything smaller for a full size ATX MB that you can recommend? There is still a lot of space inside that will be wasted and I will not need drive cage and optical drive. Something clean and minimal, around $100
Here you go
Is an ATX but tiny
That's literally the case I was going to recommend. It's only got 4 inches to spare depth wise, that's it. It's the smallest ATX case I've ever worked with.
NZXT S340
A little larger than the one @Cavemanthe0ne posted, but a little smaller than the Corsair 400C. Cheaper than both as well.
Perfect! Thanks!
