Hello all,
I am looking for a case that has good airflow and also has handles. It would be helpful if you left suggestions down below.
Moose
Hello all,
Moose
What mobo compability and size are you looking for?
I am looking for a case on the larger size case.
M-ATX or ATX or Full tower EATX ?
full tower please. I would like a big case beceause this will be my first build and it would be difficult for me to build with the smaller cases.
http://pcpartpicker.com/p/xyc
http://www.rosewill.com/products/1798/ProductDetail_Overview.htm
http://pcpartpicker.com/p/FYPx
What's your budget?
I would just get a Fractal Design Define R4. It has 140mm fans (filtered intakes), looks good and isn't that expensive. Also it's insanely easy to build a rig into because of the cable routing options and the large space behind the motherboard tray.
You can just get a plate, handle, bolts, nuts and mod the handle to the case.
Off-topic: Is it just me or can't people use search engines anymore?
Koonikko I did use google to search but I asked people on here to see what there opinions were.
I found these two full towers with handles http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245 and http://www.newegg.com/Product/Product.aspx?Item=N82E16811119260. If i find anything else i'll let you know.
