Hey guys I just built my new computer but the case I have doesn't support the h100
This Christmas i got $200 to spend. $100 of it is going to the h100 and the other half is going to the case. I don't really know a lot about cases and which ones will fit the h100 so if anyone has any suggestions and can point me in the right direction that would be awesome
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147170
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146084
theres two from what i can see that should be able to top mount the radiator.
I would try for the NZXT Lexa S, it does support the H100, also has a side window, and decent cable management
