Looking for a 4-Monitor 4-PC KVM switch
Hello again!
I’m currently in search of a DisplayPort KVM with EDID emulation.
Issue is - the ones i’ve found are unobtainable here locally (or anywhere at all).
At the very least i need 3-monitor 3-PC one.
The ones that i’ve already found:
  1. Rextron PKAG-G3144, not sold anywhere
  2. SmartAVI SM-EDPN-4Q, not available locally
There are several KVMs on aliexpress, that almost fit the requirements (3-Monitor 4-PC ones, with 1xHDMI and 2xDP ports), but those don’t have EDID at all, and others (with 2xHDMI and 1xDP ports) have EDID only for the HDMI part.
I have 2 DP/HDMI and 1 HDMI-only monitor, and the current PCs’ outputs are from RTX2070s (Aorus one) and AMD Pro W5500 (4xDP)
Do you, the forum, have any other recommendations?
Found a similar one on aliexpress, but it’s EDID support is currently not known.
And another one from CLK, 944HUA-5. Also not available locally…
Almost perfect fit from Alibaba, but yet again - not shipped locally.
With a similar one on Amazon, just with HDMI instead of DP.
Alternatively, will this sort of setup work properly?
Server 2 does not physically exist at the moment, and if its 3x4 KVM - there might be a 4th system. PC may switch over to the same DP-only output later on.
