this is “the deal” right now, if you don’t mind LOUD. I mean squirrels in a blender loud.
48 10 gig ports, 4 40 gig ports. Firmware is Linux, but hardish to get.
Sometimes 24 port versions of this comes up. Avoids the all-sfp switches which,imho, are basically EOL even for home labs since so much better stuff is available at this point.
If you can get by on only 2 10-gig ports, Asus has a smaller switch, you can sometimes find on sale for $199, that also has more 1 gig ports.
There is prettymuch nothing in-between that’s not garbage, sadly. Except for the sfp+ stuff. But that’s actually deceptively expensive because you usually need at least several sfp+ adapters or transceivers.
I’m in the middle of a project now to revamp my home networking with more reliable pro equipment – I wanted to go 10G and grabbed an Aruba Networks S2500-24T. It’s managed, rack-mounted, 24 gigabit ports + 4 10G SFP ports. You can also find them in 48 port varieties and the model that ends in P instead of T will give you POE too.
You can find them easily on eBay for less than $100.
I found this deal after discovering this YouTube video that explains how to set this switch up and set the 4x10G ports up correctly (instead of the default which has 2 ports used for stacking).
I picked up a Molex 74752-2501 DAC for $15 for connecting this to my storage server, as well as a pair of ipolex 10G-SFP-T-Ubiquiti 10GBASE-T transceivers so I can connect with my workstation via cat6. Both of these transceivers work great.
Noise is very low after bootup (I’m using it next to me in my home office without noticing it much) but there’s also a video on youtube for modding it with Noctua near-silent fans.
I found this switch at work in our depot that I can grab for free.
I just need to get the 10Gb base t module and a couple 10t Gbics. I guess I can live with 2 10GB ports. Just really preferred 3. However if it saves me $400 to $600 I think I can get over it.
I think I saw a refurbished one for about $250. We have a Website at work where it shows all of the equipment available and they dont have the darn modules there.
$250 for two ports is pretty bad pricing and two doesn’t leave you much upgrade room.(note I have the expansion card) really would go elsewhere if you want 10gbe imo
I mean for double you can get 12 ports
Any reason you would avoid the Aruba suggestion then?
~$100 for the switch and if you did four 10GBase-T transceivers at ~$40 a pop you’d get 24 gigabit and 4 10G ports for roughly $250 total, even cheaper if you don’t do 10GBase-T for all 4 ports.
No reason. I posted my comment before I saw yours. Where did you get the 10base t transceivers? And did you do a speed test to see what you are getting on the 10GB interfaces?
I used these transceivers: https://amazon.com/gp/product/B01M5LIUK5/
I don’t know if you could find anything cheaper. This is my first switch with SFP+ and I am learning as I go.
As far as a speed test goes, this is what I’m getting as long as jumbo frames are enabled on both the iperf3 server (ubuntu machine) and client machine (ubuntu on wsl2/win10):
Been using this for a few months without any hiccups, just followed the basic setup video I mentioned in my above post and ran iperf3 with great success. In real usage my storage doesn’t remotely hit that kind of performance, but that’s not the switch’s fault.
There is a Mikrotik 8 sfp+ & 1gbe switch for ~250, but you need to provide the sfp+ adapters and is passively cooled so no noise. If noise is not a concern just go with used enteprise gear.
