Longest AIO water cooler tubes?
Basically what the title says, looking for whichever aio has the longest tube length. Or suggestions to which ones can be replaced with custom tubes ?
Thanks !
You can replace any of the AIO coolers tubing. Worst thing is though its 6mm id stuff. Be sure to have everything is full of fluid before turning it back on though. The crappy magneto impellers are easy to knock off balance with big air bubbles.
As for the longest, since 90% of them are asetek units the tubing lengths will roughly be the same. Models like the h100 have tubing that is long enough to reach the cpu in pretty much every run of the mill case.
My advice, build a proper custom loop kit if budget permits.
