Long Term Storage - Discontinued Drives
Hey everyone!
I’m trying to think about the long term requirements of having a large storage server, so this is a hypothetical situation. Obviously, drives will fail over a long enough timeline, and the solution to that problem is to replace the failed drives. Lets say you made a storage server years ago when 4TB drives were very common, but the manufacturer doesn’t make as many due to the development of higher capacity drives. I was wondering what solutions existed for situations where the size of your drives isn’t manufactured or available to be purchased anymore. Do you simply re-silver the entire server at once upgrading the capacity of your server, or do you try to find another brand of drives and mix those in with the other working ones? Anyone who has experience dealing with a situation like this or something similar please share your thoughts, thanks!
What file system? Whats your set up look like?
I have always shuffled my old drives down to long term backup and upgraded the drives being used to larger ones so lose some redundancy in the back up drives and keep more failure tolerance in active.
I do not have experience with large numbers of drives, but I do have 2 sets of 4 in my NAS, 4x4tb and 4x10tb. When I purchase drives I order 6 so I have spares. Each set is its own pool. My plan is that when I run out of spares I will either purchase new spares or order a new set of 6 at a different capacity and replace them. I started with the 4tb drives and bought the 10’s several years later.
Back in 2008 in my first NAS I used 4x 500GB drives. Currently I’m on 6x 16TB drives, always in RAID6. When I upgraded from 500GB to 2TB, and later 4TB drives, I swapped out one drive at a time re-silvering every time in between. Took ages, but no data loss. Then corona hit and as energy prices soared I shut down my NAS and concentrated my data on a single 8TB drive in my desktop. Bad practice, but circumstances etc :roll_eyes: The current NAS I build “new” (old hardware, recertified enterprise drives) and after re-silvering the 6-disk RAID6, I copied over the data. Took ages, but eventually succeeded. I must admit my storage usage exploded since corona and I’m already eyeing up another 16TB drive I found in an unused system. if that’s not a backup, it’s game for expanding the NAS, totalling 80TB of useable storage :stuck_out_tongue:
@mutation666 Well it’s a hypothetical scenario, but let’s say the server is running TrueNAS and the hardware is fairly basic with only 12 HDDs.
I like the idea of rotating drives over to the backup storage!
@Cl0udb3rry87 That’s an interesting idea of building separate pools with each new set of drives! It would be a good work around for any potential conflicts using different types of drives in the same pool. Although, I’m not sure how much of an issue that would be in the first place.
@Dutch_Master You seem to have experienced what I asked about, and went through my nightmare of re-silvering everything :smiley: but it seems like you managed to make the best of it regardless!
I just worry that unless I frequently upgrade the drives and other hardware, it will be harder to ensure that I can find replacement parts as the years go on.
It’s not a nightmare, just a nuisance. And time-consuming :roll_eyes: But as long as you change only a single disk at a time (and you run RAID5 or 6) there’s no real risk to the data stored.
Since I have little experience with ZFS, but much more with mdadm RAID systems:
I went with RAID10 and now I can always add 2 drives to the array and get one driver’s worth of capacity.
And if one drive failed and I didn’t have a spare, I could use a similar or higher-capacity drive, but would only get the old (smaller) size.
Once the other drive in the pair is upgraded though, from what I remember I could just grow the size of the array and of the partition(s) on it.
I have not found a perfect solution for this for the small scale. Drobo was posed in the market to fix it, but they are no more.
I got tired of doing the RAID drive swap when I needed to expand, so last refresh of homelab, I did a small 2 node Ceph cluster. Pair of Dell R710 with add on PowerVault shelfs. About 30 HDD of spinning rust. Servers are basically in a mirror so a copy of the data exist on both servers. Ceph hates me being so small, but it lets me add and remove drives of any size, at any time. As long as I do them in pairs so both servers match in total storage size.
This is the most cost effective solution I have found without piling everyone on one server (and eggs in one basket).
