I do not know, since I only use the mice as wired and NOT wireless.
Yes I’ve tried the wireless mode but it’s not responsive enough for me and the shape of the mice is what I’m after, the ergo shape and the weight and the fact they are NOT tiny in my hand.
Hm, I also have a g700s and get similar symptoms when I unplug or plug in the mouse. Sounds like the USB connection on the mouse end is flaky for your mice.
How about trying a different USB cable. Ideally one that is really flexible and fairly new.
Yes. Some cables that have huge casing on the micro B end might not fit, but the port is standard.
The issue could always be with the port instead of the cable, in which case it is either soldering on a new port (if you can find a replacement that fits) or buying a new mouse.
