so I’m trying to use my second connection in case the first one goes offline. this is tricky because I want my domain to fail over to back-up ip and connection.
in hardware and on router this is all working just fine but for my website and email server not so much. this is a dns issue but I don’t really know how to deal with it
setup: pfsense router
main wan: verizon
second: comcast
website,vpn, and email server being connection agnostic is the goal. along with ringcentral phone system (gets very mad when external ip changes haha)
Well the simple answer is some sort of dynamic DNS service. I will say not changing the email server public IP unless you absolutely need to would be best to maintain sending reputation. You could get more fancy though with a cloud router(s) and dynamically routed tunnels with a floating IP address if you have multiple. Really depends on how much you want to over engineer this.
the dynamic DNS is what I’m going to try first, but thanks for the hint with floating IP, that is a way more robust solution but best to start with something easy first haha
