I applied Liquid Metal to a laptop. The laptop is running great and after moving it around a few times, I checked the liquid metal. The liquid metal didn’t move around at all.
But i still don’t have any material used to prevent leakage.
Typically the PS5 and liquid metal laptops have some kind of leak prevention method.
The PS5 for example has a black sponge around the die.
Does anyone know of a product or products that can be used for leak prevention?
Some type of thin sponge and perhaps a special type of glue to connect it to the captain tape I already have installed.
Needs to be thin enough to not obstruct the die and heatsink from making contact.
