i been having a bit of an issue with my Mic on Linux, its all crackly and its somewhat annoying for those having to listen to it on the other end. also i cant do video recordings with voice over as it sounds aweful.
im using the onboard sound card on my ASRock Fatal1ty b350 which is a typical el trasho Realtek card (spits on realtek). So im wondering if there is a fix for this OR am i better off getting the sound card i want which is a Creative Sound blaster ( Creative Sound BlasterX AE-5 Hi-Res PCIe Gaming Sound Card) yes a bit pricey. but im over bad\realtek audio quality.
and does creative have better support then real(bad)tek ??
yeah im thinking ill be spending the $200 on a creative cards going to be the way to go.
the realtek stuff just doesn’t cut it for me, fidelity just isn’t there.
well it does it whether im using my headset mic OR im using my other mic with a phantom power pack. everything is on default as far as i know. it seems to only be on the mic line thou, the rest of the audio seems fine most the time. it sometimes can stop working on youtube. but the mic is always bad
You are literally not helping. Embedded sound is just fine. Only really high end cards are good for production for listening at 24 bit 96 khz as your max the THD is gonna be better on motherboard due to noise being less in the isolated section of the motherboard itself. This has literally been proven. If he wants a high end card for production cool im all for it.. do what you do but if its general listening its NOT necessary
Alright lets identify the sound card first.
Use pacmd and then list your sinks put it here
also verify its recognized correctly with sudo aplay -l
Then of course run lspci -v | grep -A7 -i “audio” to see if the right kernel module is loaded for the chip
Once you do Ill look through it see if everything is recognized correctly and then move onto your mic..
I had a Sound BlasterZ and the only way anyone could get it to work was using the front panel connector in 32bit linux. AFAIK all of these cards use the same Recon3D driver ported from chromeOS and they either don’t work or barely work. That said, there has been some movement on LKML since kernel 5.0 for getting the driver fixed so it may work better now or in the future.
Hopping on this thread to watch. I have the realtek adapters, same issues - I was able to improve them with the above fixes - playback is about perfect; input still fuzzy/static. Good enough now (just barely) to use for discord/etc - but abysmal for recording. Tried the fixes on 4xx and 5xx, ubuntu, fedora; etc. I gave up for now and put win 10 on a separate drive - perfect/clean audio there
