A simple option to keep the phone screen on while charging would be fantastic… Of course, it’s easy to say “a simple option”, but I haven’t the foggiest idea how easy that would be to implement.
I have a Volla Phone coming in the mail. It looks to be a promising phone that ships with Ubuntu. I’ll of course keep you guys posted on it.
So power management is done through a series of settings, which are controlled by a daemon. You know, linux power settings on a normal laptop? Same deal. It’s just config files written and a kill -USR1 sent to the daemon to reload the config.
At least to the best of my knowledge.
So I don’t see why we can’t have a dbus hook that monitors power adapter plug in and removal.
I might give it a go one of these days, but currently I’m busy rebuilding my work’s entire production stack.
Systemd has native inhibit features. Might be useful to start there.
Various power managers do have support for all of these things. It’s less a matter of implimenting features than figuring out why they aren’t working on these Pinephone builds.
Now I just need to figure out how to use it… Its got one of the KDE versions on it right now, not sure which. I open up one application and then I’m stuck. Can’t get back to the home screen without a reboot.
I’m probably going to have to try out some different OSs
It’s really easy! Just flash one of the distro iso to an SD card and pop it in. I use Rufus on Windows.
If you want to install it on the eMMC then there’s an added step. You’ll need to install jump drive to an SD card, pop that in the phone, and then pug your phone into a PC. Then flash the OS to the phone.
Links are in the first post at the top of this thread/topic.
Tried arch, manjaro, postmarketos, and mobian. Most of them in both phosh and plasma if available. I cant say I’ve seen a lot of difference other than plasma vs phosh.
I did run them all on old 8GB micro sd cards that made the pinephone feel sssslllloooowwww so they all seemed pretty rough.
Sent from arch phosh installed on the emmc. Much faster. Usable level of speed but not lightning fast.
Because mine cough fire …
Those phone were really nice, QI charging pogopin header, swapable everything, but when i found mine fused to it’s charging dock that close to my bed …
Nowdays batteries safety tech are very cool to get.
