I’ve build a new PC this weekend with linux manjaro/cleanjaro on it. But i can’t get audio over hdmi to work. I connected my monitor via hdmi to my videocard. I have a amd/ati rx580 with ryzen 2600x if that helps.
I tried nearly every guide on google. Nothing worked so far. It always says Digital Stereo (HDMI) Output (unplugged) (unavailable) in pulseaudio. I tried to install normal manjaro, debian and ubuntu and also live medium.
Tried different cable, monitor and tv. Also tried to disable onboard audio in bios. Tried different kernel versions (4.19, 5.2, 5,3, 5.4). Tried adding amdgpu.dc=1, amdgpu.audio=1 and radeon.audio=1 to /etc/default/grub. I recently installed xf86-video-amdgpu-git 19.1.0.0-1 with kernel 5.4. Still nothing.
does your monitor have a ground connection? The 3rd pin in the power plug? Ive had some issues in some HDMI that refuse to function without grounding (maybe as a safety feature?).
No it doesn’t. But i don’t think it’s a cable issue. I don’t have other cables (3 pin) to test that. Audio over hdmi works on all other devices but on this PC. I think it’s an software thing. Nothing on the internet that worked for toher people worked for me yet. I’m out of ideas.
I can try another videocard, but that won’t fix my issue with the rx580.
Can confirm that it does/can function properly w/ r5 1600, rx580, msi tomahawk, ubuntu 19.1 w/out any fixes… not that I use it since the speakers on my tv/monitor are terrible.
But I’m assuming you tried ubuntu 19.1 or .10 in a live environment? Maybe check out what alternative audio driver packages might be available/work with your system.
I don’t know how to do that, to be frank. AFAIK i have pulseaudio installed.
Yes, it works on every other device i’ve tested so far.
In Valume Control > Configuration i have 2 Profiles, one for HDMI and the other HD Audio Controller (thats my motherboard and front panel). HDAC works fine, but i want audio over HDMI.
When i type alsamixer in terminal i can see PulseAudio for Card and Chip at 100. Pressing F6 and selecting sound card > 0 HDA ATI HDMI shows HDA ATI HDMI for Card and ATI R6xx HDMI for Chip but everything on 00 and i can’t change anything. No Master Control.
Well, yes. That Model has, as seen in the pictures, 2 HDMI ports. Mine has only one. I can assure you it does, since all my devices are connected via HDMI.
