so two issues 1 I don’t think can be fixed.
I have to install dinput8 with winetricks to get voice-overs and other stuff from the evo mod of trails in the sky and this breaks gamepad support in wine (the only solution as far as I know to this would be not to use the mods or use steam input to make the controller emulate a mouse and keyboard (which is what I do))
because I am emulating mouse and keyboard with a controller sometimes other applications will take control away from the game, for example, some times ill randomly alt-tab when I don’t want to. or I can hear steam moving through its menu while I am playing. is there a way to block other applications from using the emulated input? ( i been told that a solution fo this could be running a separate xserver however i have been googling, asking on Reddit and other discord servers on how to do this and I haven’t figured it out supposably all you have to do is run this
xinit vkcube -- :1 vt$XDG_VTNR
for example but this gives an error about having a xserver already running
