So after being super disappointed in my Asus b350 prime, mostly because of the VRMs i switched to the MSI b450 gaming pro carbon plus (got it fairly cheap). So far OC wise its not too much of a difference, reached 4,0 GHZ on the r5 2600 easily by just typing it in the multiplier (on the Asus i had to offset the Voltage by 0.27 V to 1.41 Volts ) and the board managed that easily by adjusting the Voltage. Since I wanted less than 1.4 V I tried undervolting which didn’t seem to affect the Voltage as much somehow but I am okay with it. RAM speed was easily on 3200 instead of 2933 mhz still try to get the timings tighter. So far so good.
Performance? didn’t change at all, if at all it got worse in CR15 from inconsistent 1250-1370 to a conistent 1269 and only that no matter what i do.
Soon i would like to upgrade to 8 Cores , mostly because when I stream bf V Performance dips under 60 FPS and seems to microstutter somehow.
Would the board stay suitable for lets say a 3700x ? Will PBO XFR and such work without a Problem ( even if i only use the 8 Pin CPU Power and not 8+4, since my corsair RM 750x only has 8 PIn) ?
Or do I have even more headroom?
thanks in advance guys and girls
I would give the b450 a try and if you have VRM concerns, just zip tie a small fan over it. I lucked out with my 2600 and run comfortably with a 4.2 oc with a asus b450-f, LLC, also well ventilated case, water cooler, and stock heatsink fan over the vrm. Concerns with vrm temps is probably because most people use tower coolers or water coolers that remove the stock coolers blowing air down that cools the surrounding areas. If you stick to the 8 cores I don’t think the 2nd 8 pin is needed. Some of the online channels when they first revealed the new boards said you could probably run the 8 cores and 3900x with one 8 pin not plugged in. The 2nd 8 pin is for the next R9 coming out most likely
Pretty much all B-450 boards are kinda crap vrm wise.
Non of them are good enough for a 3900X.
The best B450 board basically is the Msi B450 Gaming pro carbon Ac.
Which is a 4+2 phase with doubled up components on each phase.
They still use some cheap mosfets.
But if you cram double the amount of them in parallel per phase,
then combined they don´t suck as much.
But still pretty poor desgins, decent for Ryzen 5 cpu´s.
But yeah not for a 3900X really.
Thats kind of the point of B450 though.. cheaper motherboard.. cheaper but capable CPU like an R5 and have a slightly more beefy graphics card and some cheap sata SSDs and you have a decent budget gaming rig. IDK why so many people hard core focus on CPU power when the Ryzen 5 or even 7 is plenty fast
Exactly that. AMD markets X chipsets to enthusiasts, B to the normal people and A for office boxes.
Okay thanks Guys, sorry for the late reply i was offline a couple days (yes it happens).
So i guess the 3700x it is If i get a decent deal on it . I guess a spare fan for vrms should lay around somewhere so i give that a try . Also i am Not sure If there are sensors on them but by now they seem fairly cool during load, at least in HWinfo
So little update if anyone cares:
3700x works reasonably fine in the b450 . Boost up to 4.325 GHZ in AGESA 1.0.0.3 , which according to DER8AUER happens every now and then depending on MB and CPU. VRM never exceeds 50 C which I also find okay. I didn’t undervolt yet, that could lower temps as well, but all in all I am happy with the result. the boost maybe gets fixed with BIOS updates
