LGG3... Screen fix?
I was just using my g3, when within a second I witness the lcdpanel dim, fade and change colors, to black.
Since i rooted it and am running a custom rom I dont necessarily want to go to the verizon store.
best course of action?
Does It seem to be running otherwise? If so a screen replacement ought to be enough. Has it been repaired before?
Flash stock and go to verizon? Who knows, maybe flashing stock will fix whatever issue you might have.
yes, it runs but the screen does not turn on..
lol I can even use an app to send texts from my computer through my phone
might just get a v20
can we get a picture of the screen?
I don't know if Verizon applies their own return policy but LG accepts any phone for repairs even if it's running a custom ROM and under warranty (not this case I guess). You could try to disassemble it, buy a new screen and make it working again. iFixit has a pretty good tutorial on how to disassemble it.
the lcd is dead
looks the same as if its off
Where can I find onE?
Ebay
im a cheatskate
or i could just buy a used one for $70 more...
or new on ebay
hmmm... decisions
I found a fix. I took the phone apart and cut a peice of a credit card up and stuck it between the cpu on the motherboard and the lcd. The lcd connector got loose.
