Hello.
I have several servers with [AMD / ATI] Tonga XTV GL [FirePro S7150V] video cards installed, they support SR-IOV Proxmox is used as a hypervisor.
I have successfully launched virtual video cards in guest systems using the GIM project. But I cannot connect to the guest machines using the SPICE protocol, I only see a black screen.
Can your project be used to use SPICE? I understand that you have declared usability for VGA PCI Passthrough, is it possible to use it for SR-IOV?
