So I have ubuntu 20.04 installed on my computer using the proprietary Nvidia driver for linux.
I’m having a couple of issues -
I’m using an LG G1 OLED TV as my main display, connected using a Displayport to HDMI cable.
1st issue.
In 1080p resolution the image does not fit inside the display so I have to move my mouse outside the boundaries of the display to be able to click in anything.
2nd issue.
4K resolution is not an option available in the nvidia-settings program, I don’t see an option to create a custom resolution.
3rd issue.
4K resolution is not an option in Windows 10 either.
Your other issue at 1080p is almost certainly that your overscan setting is incorrect. You must change the setting in the TV so you can see the edges of your screen properly.
*Club3D adapter requires at least Turing or Navi Gen 1 to work with DSC 1.2, so don’t go out buying that adapter unless you’re on at least Turing or the 5000 Navi GPUs.
Is there any way to make my graphics card output through the HDMI port first instead of Displayport?
Annoyingly I can’t see the POST screen unless I use one of the Displayport ports on the card - the Displayport to HDMI cable I was using before confirmed this.
