Welcome to the verification gateway for the unofficial Level1Techs Fluxer community.
This space is an experiment in building a high-trust, low-slop real-time chat and voice server on Fluxer (fluxer.com ). To maintain the signal-to-noise ratio and prevent the toxicity and burner-account trolling that plagues public Discord servers, access is strictly gated to established community members holding the Regular (Trust Level 3 or higher) badge on forum.level1techs.com .
The Core Philosophy: “Skin in the Game”
On traditional public chat platforms, anonymity and throwaway accounts disconnect people from community norms. This community is structured around reputation staking :
- Identity Linking: Your Fluxer presence in this community is permanently tied to your forum persona. The automated gateway forces and locks your server nickname to match your exact forum username.
- Behavioral Accountability: Being a forum Regular grants you access through the door, but it is not a free pass. There is zero tolerance for abuse, harassment, or bad-faith trolling. If you cause problems in chat, your access will be revoked immediately.
- No Burner Alts: The system strictly enforces a 1:1 account binding . One forum account can verify exactly one Fluxer account, and one Fluxer account can only ever be tied to one forum handle.
Security & Anti-Gaming Rules
To keep the onboarding resilient and prevent exploitation, the verification engine enforces strict validation checks:
- Strict 1:1 Identity Lock: The verification database records both your forum username and your Fluxer User ID.
- You cannot verify multiple Fluxer accounts using one forum account.
- You cannot verify multiple forum accounts using the same Fluxer account.
- Attempting to post a second ID will be automatically rejected.
- Trust Level 3 (Regular) Enforcement: The gateway parses this thread. If the account posting the reply does not hold
trust_level: 3(or higher / staff status), the request is rejected immediately. You cannot piggyback off someone else’s badge. - Hijacking Prevention: If someone posts another member’s Fluxer ID, the system binds that ID to the poster’s forum account and sets the nickname to the poster’s name. It does not grant them your identity. However, posting an ID that does not belong to you will result in a permanent block from the gateway.
- Loss of Account / Re-binding: If you abandon or lose access to your Fluxer account and need to re-link, you must contact @MadGoat directly to review and clear your database record.
How to Join (Step-by-Step)
Step 1: Join the Fluxer Community
Accept the community invite link:
(Note: When you join, all chat and voice channels are private. You will only see the #welcome-and-verify channel until your role is assigned).
Step 2: Retrieve Your Fluxer Snowflake User ID
Fluxer uses standard 64-bit Snowflake IDs (identical to Discord):
- In Fluxer, open User Settings (the gear icon next to your avatar at the bottom left).
- Go to Advanced in the left sidebar and toggle Developer mode to ON .
- Close settings, click your profile picture in the bottom-left corner or member list, and select Copy user ID .
Step 3: Reply to This Thread
Post a reply to this thread containing your Fluxer ID.
Frequently Asked Questions
Is posting my Fluxer ID safe?
Yes. A Snowflake ID is a public entity identifier, not a password or auth token. It is transmitted openly in standard client traffic whenever you send a message or join voice. It grants zero access to your account, tokens, or private messages.
Can someone steal my access by posting my Snowflake ID?
No. Verification flows strictly from Discourse → Fluxer. If someone else posts your Snowflake ID:
- Your Fluxer account receives the
@regularrole. - The person who posted it receives nothing, while permanently burning their own forum account’s single 1:1 binding on your profile.
What happens if someone tries to maliciously “lock” my ID before I post it?
Because submitting an ID requires Trust Level 3, any attempt to bind someone else’s ID leaves an indelible, public audit log tied to a high-reputation forum account. If someone attempts to grief your ID, ping the moderators—the link can be purged from the gateway’s state in seconds, and the offending forum account will face moderation.
Can I verify a friend’s account who isn’t Trust Level 3?
Not without consequences. Every forum account gets exactly one lifetime binding:
- Their Fluxer account will be permanently renamed to your forum handle.
- You will never be able to verify your own Fluxer account.
- Any behavior, rule breaks, or bans incurred by that account will be treated as your own on the forum.
What if I posted the wrong ID or made a typo?
If the bot skipped your post due to invalid formatting or non-Snowflake characters, simply edit your post or reply with the correct ID. If you accidentally bound the wrong active account, ping an admin to clear the incorrect entry.
Why the “Regular” (TL3) requirement?
The Level1Techs forum relies on Trust Levels to measure long-term, positive engagement. Gating chat to TL3 ensures that everyone in the room has a proven track record on the boards, eliminating spam bots, ban evaders, and low-effort drive-by posters.
What if I’m Trust Level 2?
Keep reading, participating constructively, and engaging on the forum. Once Discourse promotes your account to Trust Level 3, drop your ID in this thread to gain access.
Can I change my server nickname in Fluxer later?
No. Server nicknames are locked to your forum username by design so everyone knows who they are talking to.
