Hello, I recently bought a level1 kvm, and was hoping I could get some assistance.
Starting a few days ago, whenever I switched to the second port, I would be unable to switch to another port using the physical buttons. However, switching with scroll lock seems to still work. This only happens when I switch to port 2. All the other ports can be toggled between using scroll lock, ctrl, & the physical buttons.
Normally this is handled through email, I believe, but I don’t have the address on hand. In lieu of that, I’ll just get Wendell’s attention. He can either help you here or advise you on how to proceed.
Hmm, anything around the button cutout? Any chance it’s getting stuck on something? When you press another button does it flash red for just a moment?
Symptom sounds like button 2 thinks it’s being pressed and then held down. You might tap the button lightly just in case there is some debris interfering with the button press.
