Can the dp repeater & splitter output different resolutions and framerates on the dp and hdmi simultaneously?
The source from the pc is going to be 1440p 144hz via dp 1.2 cable, the screen thats going to be connected to the dp out of the splitter will be 1440p 144hz as well.
Now on the hdmi i am planing to connect a pikvm v3 which can do 1080p 50hz max. Will this work or will the output going to my screen via the dp also drop down to 1080p 50hz (or 30hz if i set that on the pikvm)?
Will i need an additional hdmi downscaler to achieve that?
I am not worried about screen tearing etc on the pikvm since it is just for recovery in case the main system has a failure.
